Do you have a model number for this watch? That would help find more information on it.
Try this. Don't worry you can't damage the watch by messing with the buttons.
Press and hold "Mode" for 3 seconds. One of the digital displays should start to blink. Now press the "Start/Stop" button once. It should do 1 of 2 things. Move the 'blink' to the next number or change the number on that display. If the "Start/Stop" button does one of these the "Reset" button should do the other. Pressing "Mode" again should turn off the blink and go back to the normal display.
The analog hands and face are clean looking and manage to give the watch a classic face. It won't turn any heads, positively or negatively. The hands are rather thin and silver which makes it blend in too easily with the face. Stupidly, Casio put a vertical and horizontal silver line on the face which further causes the hands to be visually lost. The hands aren't hard to see, but because they blend they aren't easy to see either. And there is no second hand at all; but the digital portion covers that function.
The digital portion in the bottom can only display two rows of information. So it's either day/date, or time/seconds. The top row is hard to see because the face shadows over it partially. The numbers are on the small side; not for old eyes. The digital portion has all the fundamental functions: time/date, hourly chime, chrono, 3 alarms, count down, dual time, and even "data bank" which is a very crude phone/number data bank.
The LED's are the old 80's yellowish tinge type and do a very poor job of illuminating the face... but if you're in the dark, it'll do the job. The hands have glow in the dark paint on them which also helps you just barely make out the time in the dark.
There is just nothing great at all about this watch; but it does everything you REALLY need a watch to do. Couple this with the 10-year battery, 100M water resistance, and $25 price tag, and you have something that just gets the job done reliably and economically. It might be plain vanilla, but it's real and hits the spot.
Hi there! A Nooka watch flashes and beeps when the battery is almost at its end. The battery required is a CR2016. You should be able to get the battery replaced at any local watch repair or jeweler!
In general this watch is set by setting the digital portion and the hands will set automatically. Start there. There are other potential problems but start by setting the digital. Make sure the battery is charged first. If that doesn't do it, then you may need to do a reset (see the instructions). This will insure the hands all line up at the 12 oclock position. Try setting first however the digital portion and see what happens
There is a reset procedure for most LCD watches to reset the LCD after installing the battery. It is different for every watch brand and movement (inner works). I recommend visiting your local Certified Master Horologist for proper battery and resetting procedure.
Improperly resetting any digital watch by shorting the wrong connection can essentially short out the movement, and the movement / watch must then be replaced, whichever is least expensive.
The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
After the time is set, press the upper left button to exit the digital time setting function.
Setting Analog Time
You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Check your users manual if your watch have two batteries. If yes, you need to replace digital part battery.
If your watch has only one battery, your digital screen or plate is defective. Bring it back to the retailer and ask to replace for the decently working watch.
But first of all try to fiddle with all pushbattons- sometimes it helps.
