Says lower presser foot, but that doesn't fix it.
SOURCE: Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
SOURCE: "Lower presser foot" error on SE 270D
OK; My SE-270D is about 5 years old and it just recently started giving me the "lower presser foot lever" I have already spent $30 going on line to fixit websites only to be told to take the unit to a service center. I went through the normal routine of trying to reset the computer of which did not work. I can't afford to spend $75 just to let someone look at my unit and then pay even more to have it fixed. I could buy the same machine or equivalent (brand new) for about $200. I am sort of mechanically inclined so I decided what the heck, I will just open up this machine and try to figure it out myself. I mean what do I have to loose. I opened up the unit and discovered there is a tiny "pressure switch" which is activated when the lever is pushed up or down. When the lever is up the switch is "off" when the lever is lowered it releases the spring loaded whitch to the "on" position. The tiny switch is right below the thread tension dial. I discovered that the switch could be activated manually by pulling it over with my finger. I had to make a hole in the casing so I could get to the switch after I put it back together. WALA! it works. When I lower the presser foot lever I then pull the broken switch into the proper position and it works like a sewing machine. I gambled on this solution because I have a tiny bit of mechanical knowledge. So if you are lacking in that area, please don't try it.
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
