Go to Nikon website and load up the Nikon Camera Control Pro2 software.
Then connect camera with the USB Cable from camera to computer.
Turn on camera.
Wait or click on Nikon Camera Control Pro2's Icon.
If you did not format the internal camera memory, you can initialize and install: Set the camera to OFF. Remove the SD card and connect the camera to the computer with the USB cable. The computer and camera should negociate and the camera should initialize and it asks to install the software.
Hello. I'm not sure if the camera has failed but try this sequence.Plug camera into tv then turn on camera then push review button. This is the only way 2 of my cameras will work for tv viewing.
Builderdale
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
Hold the camera so that your fingers do not touch the lens unit when you are shooting.
Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred.
Please do rate this solution as FixYa and revert for further assistance.
Thanks Rylee
