Really would like to find a manual for this thing
SOURCE: Frigidaire (Model # CFEF312GSA)
sounds lke an electrical issue , go check the breaker ( should be a double breaker) fully turn off and reset, if that doesnt work id check the connection behin\d the range making sure all the wires are properly secured, doefinalty sound slike a lack of power issue
SOURCE: My frigidaire oven is 6 years old and the clock
your model # is not full but i found unit and the # is 31818541 it coast 177$ in sears part... it is easy to do by yourself just get the right part and call sears part...
good luck
SOURCE: Frigidaire Stove clock resets to 12:00 when igniters turned on
I have the same problem. This is an intermittent problem, maybe once every 20 to 30 starts the clock goes resets and the appliance beeps just like if unplugged it and then plugged it in again. I’m an electrical engineer and this sounds like the microcontroller that runs the appliance is being reset by noise caused by the spark igniters. This is definitely a design problem. Separating the wiring of the igniters and the control board should help. When I get a chance I’ll have to connected an oscilloscope and look at the noise. The control board microcontroller reset pin probably needs an RC snubber or an isolated ground. If /when I find something more definite, I’ll place another posting.
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
