I believe what you are asking for, is a Motherboard Manual, for the motherboard used in an Acer Aspire M5400 desktop computer,
Not available.
The motherboard is made FOR Acer, by a motherboard manufacturer.
In this case the manufacturer does not supply information.
Acer does.
Motherboard,
http://www.shopping.com/acer-acer-mb-se109-002-aspire-desktop-board-motherboard/info
Specifications,
http://support.acer.com/acerpanam/desktop/2010/acer/Aspire/AspireM5400/AspireM5400sp2.shtml
With the above information you can see;
1) Processor Support.
2) Uses a Socket AM3 processor socket,
http://en.wikipedia.org/wiki/Socket_AM3
[ Look at the list of AMD Phenom II, and Athlon II, processors.
Now look at this chart, {Scroll down},
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#Phenom_II_series
Now look at the processor socket used for these processors. Scroll the page down, compare using the charts ]
3) The motherboard chipset is an AMD 880G,
http://en.wikipedia.org/wiki/List_of_AMD_chipsets#A-Link_Express_III
Here you see more information on what the motherboard supports.
4) The Ram Memory used is DDR3 Sdram, at either 1066MegaHertz, or 1333MHz.
(That is PC3-8500, and PC3-10600, respectively)
The Maximum TOTAL Amount for the motherboard is 8GB.
There are 4 Ram Memory slots.
The Maximum Amount for EACH one is 2GB.
NOTE*
O/S = Operating System.
Windows XP, and Windows 7, are two examples of an O/S.
With a 32-bit O/S, the maximum amount of Ram Memory that will be recognized, is 3-1/2 GigaByte. (3.5GB)
You have to have a 64-bit O/S for above 3.5 GB.
(8GB? You need a 64-bit O/S)
ALSO, don't just use any Ol' DDR3 ram memory.
I doubt you can go into BIOS Setup, and change the Voltage, and ram timings, for a high-performance ram memory.
In otherwords 'gamer' ram memory.
JEDEC sets a standard for Ram Memory.
One of the standards is the Voltage. Standard default voltage set for your motherboard by JEDEC, for the Ram Memory, is 1.5 Volts. (DC)
MAXIMUM voltage is 1.575
That Acer board is not capable of handling DDR3 high-performance ram memory, that will exceed 1.5 volts.
(Probably isn't a BIOS upgrade either)
What is it that you seek? Post back in a Comment.
Regards,
joecoolvette
JEDEC,
http://en.wikipedia.org/wiki/JEDEC
SOURCE: acer boards
this is what your comp can be upgraded to threw these specs i had in my comp book specifacations
hope this helps
Specifications
Product
Aspire E560
Language
English
Model
Aspire E560 Specifications
Specifications
Processor
Intel® Core™ 2 Duo processor up to 2.13GHz with 1066MHz system bus
or Intel® Pentium® D processor up to 3.4 GHz with 800MHz system bus
or Intel® Pentium® 4 processor up to 2.8GHz with 800MHz system bus
Cache
Depending on the CPU
Memory
256MB 400/533/667 DDR2 expandable up to 4GB
BIOS
Flash BIOS
Supported Protocols
PCIX 1.0, PCI 2.2, APM 1.2, VESA/DPMS (VBE/PM V1.1), SMBIOS 2.3,
E-IDE 1.1, ACPI 1.0b, ESCD 1.03, PnP 1.0a, Bootable CD-ROM 1.0,
USB 1.1~USB 2.0, UHCI 1.0, ANSI ATA 3.0, ATAPI
FCC, ETL and NOM certifications v 1.10
System Chipset
ATI RC415 + ATI SB600
SOURCE: Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
SOURCE: Manual Acer Aspire M7720
You can download the user manual for your Acer laptop directly from here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
SOURCE: I also have an Acer M1640 with a burned out
yes but you will have to reinstall all the acer **** you got with the pc originally and also windows as it wont jst play due to hardware change
