They sell cleaners for glasstop stoves. Often I find I can use baking soda and lemon juice mixed together to form a stiff paste and use a non abrasive pad (like what you use on non stick pans) and lots of elbow grease... but not TOO much pressure... If that does'nt do it, try the cleaner they make for it. I have had my stove for quite a while now- overall it's stayed fairly clean with the home remedy
SOURCE: Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
SOURCE: i need a glass stove top for a kenmore mnodel
you can get them at sears parts direct, but they are most likely over $200 and it may take three or more tries to get a top that isn't chipped
SOURCE: glass top is scratched and discolored...can you
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Testimonial: "Great..thank you...Hope it works...Susan"
SOURCE: Glass stove top with enclosed
Hello mfry.... It is true that these glass tops do get more brittle as time goes on and there is the chance that it could break. That said, if the top breaks, you can generally buy a replacement top. I would begin by removing the glass. If it doesn't break on the way out it probably won't break. Once the top is off, then get the replacement ignitor.
If you want to see if these parts are available get the model number and go to the searspartsdirect.com website. Enter your model number and you should get the parts diagrams along with the prices. Joe
Thanks for choosing Fixya!
