Accidentally deleted files from Cruzer micro 4 g. Use MacBook. Have had no previous issues. There does not seem to be an undo.
Help!!
Since you are using Macbook, you can go to this program USB Flash Drive Recovery for Mac for help.
If you are running a computer with Windows, go to Data Recovery for Windows. It should help you out.
Note: before recovery, DO NOT save more files to the USB drive.
There is no such undo function with Vista. Take a file recovery software to recover the data as soon as possible.
Recommended one is Wondershare Data Recovery. Get the program here,
Windows Data Recovery (Windows Version)
Mac Data Recovery (Mac OS version)
Take care - Before those items are recovered, stop saving more files to the drive! which means if you continue to save more files to the device there will be a possibility for them to be overwritten. Once overwritten, it is impossible to recover.
Have rescued your hard drive stuffs back successfully?
If not, there is a video tutorial that can help you take all deleted stuffs back step by step here:
https://www.youtube.com/watch?v=Lqb0uxpq2mQ
Just simply follow its steps and see how many of your original drive files could be restored.
Back up all deleted drive files back.
The deleted files often will not really be erased off from your hard disk. Therefore, never worry too much! In fact, these deleted files are often still stored on that Cruzer hard drive before you write new stuffs to replace them completely.
So, before they all are overwritten and damaged, you do have chances to rescue them all back with deleted file recovery software.
Simply download a proper data recovery program and follow its data recovery instructions to take everything back.
Here, read more detailed information:
How to restore deleted files from hard drive
From now on, save more copies of everything important on different devices or drives.
You can recover deleted files from Sandisk Cruzer with data recovery software, here's a good one that helped me before
How to recover deleted photos videos from SanDisk Memory Card
1. Stop using this drive immediately in
case that any new file would rewrite your deleted files and make these files
gone permanently.
2. Plunge this drive to a computer.
3. Download a hard drive data recovery freeware to restore all your deleted
files back easily.
This data recovery freeware can deeply scan
your cell phone and get back all your wanted files back successfully in the
same way as it completely regained all the data of my friend back from his
formatted WD hard drive.
If you are interested, you can download
this hard drive data recovery freeware here:
http://freeware-fix.blogspot.com/2013/03/external-drive-data-recovery.htm
4. Save and back up every restored file on
another drive or storage device in case of data recovery failure.
if you mean you have accidently deleted your files from your scan disk
you could try this software to recover them
there are plenty of free recovery programs on the internet if you are unable to recover them with this one
Free File Recovery is a small and easy to use application that will help you to restore files that have been accidentally deleted from your computer.
This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from
digital cameramemory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
hope this helps you
I'm using win vista with cruzer micro 8GB and also can't find the undo...
