I forgot my security code in restore setting i can't format my phone plzzzzzzzzzzzzzzzzzzzzzzzz help :(
No problem mate. Nothing to worry. If you have forgotten the security code for your Nokia 5130, You can do a master rest to your phone. This would restore your phone to default factory settings. You can get the master reset code for your Nokia 5130 from www.mobileunlocksolutions.com/nokia-dct-master-code-service/rs1wp10/ at affordable cost. All the best mate.
SOURCE: I cant restore my nokia 3120 classic to factory settings
If the default code 12345 isn't working anymore, please check out here..
Nokia mobile Codes and tips
Good luck.
Thanks for using FixYa.
SOURCE: How to format
You will need to get the code in order to access the phone. If it is a SIM card password, changing the SIM card will resolve this problem. Also, there is no way to "format" the device, you can Restore Factory Settings, but that just changes the settings back to default. Best of Luck.
SOURCE: how to format 5300 phone memory?
First you should connect data cable to your system9which is given with your box),then select nokia mode,then open my computer there you will find two drives(1st is phone memory and 2nd will be memory card)click on phone memory,right click on that,go to format option and format your phone memory.remove data cable after formatplug back into your computer you will find nothing inside it a fully new phone...enjoy!
SOURCE: i forgot my security code and now i want to
Master reset code: 0415531240
Rate this solution.
SOURCE: nokia 6103
my nokia 6103 phone can't be rest to it's original phone settings,,i mean restore factory setting,it needs a security code,unfortunately i forgot the security code..How to rest my phone to its original phone setting or how to reformat it to its original setting by manual operation..hope you can help me.....god bless...........
