The continuous flow system was installed on a canon pixma MP 287(brand new) which was a lemon, and then still hardly not used, being taken out of the MP287 and installed on the also brand new MP280. It displays on the computer that the cartridges which are the same for both machines, are not bonding with the MP280. We are desperate to get this fixed - please advise
For error e 1 4 = better take it out and wipe the smudges
for error e 0 5 = check the ink catridge, when ciss installed most installer make mistake by making the red ink hole at the circle made on it. you must make the hole slightly under it, the small hole. the big round is under the thick plastic lid, so the pipe we put will make the catridge move from the original position. or your cartridge just spoilt.
OMG!!! i tried to solve it by pressing the reset and on button but now it doesn't want to turn on :(
SOURCE: We have a Canon Pixma MP280 printer and are
r u sure that is e6? Error Code :
There are bunch of error code for canon.
Pls check below and re-list your exact error code and can help you.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 ? Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error ? USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error1
SOURCE: Get error: check ink u059 col
For me, this meant that I put it an ink cartridge that wasn't compatible.
SOURCE: canon pixma mp 110 - saying 'put in cartridge'
The print heads on this printer are integrated to the cartridges. I would check the inside of the cartridge caddy, and make sure that all of the gold contact pins are exposed, not looking damaged, and that there are no tears on the film it is connected with. If you notice anything shady with that film, you want to do an RMA (Return to Merchant Authorization) so you can get a replacement,
Canon offers a 1 year upgrade warranty with all of its printers, which very few people use or pay attention to. This means that if you did not void this warranty by using remanufactured cartridges or freaked out the chips on genuine ones by refilling past 1200 prints, you will actually get the newest model (currently the Canon MP140)
