Question about Fisher and Paykel Washing Machines
I need a Machine Diagrams of Engine and drum - Fisher and Paykel Washing Machines
  • Fisher and P... Expert
  • 555 Answers
Go to Jordan's Manuals and select your F&P model for a parts view.
You will need Adobe reader to view PDF's.
Posted on Dec 26, 2013
6ya staff
SOURCE:
LG Smart Drum washing machine. I need pump that pumps water out
Searspartsdirect.com has diagrams with all parts if you have your model #.
Oct 09, 2018 | LG Washing Machines
Belt has borken
how to open a cabinet:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt diagrams:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 15, 2011 | Dryers
Neptune MAH5500 Neptune has progressively gotten louder on spin. Very loud noise sound like bearing going. Continues to get worse. Can it be fixed or too expensive to justify?
Hi.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, Check if the drum has excessive play.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
To get a quote on repair call Maytag at the number listed on the owner manual, the machine may still be worth repairing.
You can find parts and diagrams for most models here.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Our front loading Kenmore MODEL 41742042100.has begun sounding like a jet enjine when it is spinning,someone told me that it is probably bad bearings, is it worth having this 7yr old machine repaired or...
Hi.
I
f you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
Nov 13, 2009 | Kenmore 44042 Front Load Washer
Grinding grumbling sound upon start up , continuing at a quieter sound during the cycle, loud and grumbly during shut down
Hi.
f you get a very loud noise coming from the machine, and this noiseislouder when it spins faster, then it is often because of a problemwith the drum bearing.
Nov 13, 2009 | Maytag Dryers
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint aquarious 1000 de luxe
You need to check the lateral movement of the drum if it moves by more than 1-2 mm then the bearings need to be replaced.
Apr 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wma54 washing machine
sorry but not the job i would recommend to anyone not done or watched it done before its about the most difficult job to do on any machine, even though in my 20 years experience this is the easiest machine to do a drum bearing change on, most of the machine has to be stripped down, removing all the front panel / timer panel / door seal and drum front / drifting out the old bearings fitting the new ones and rebuilding the machine, not counting testing for and rectifying any damage the drum has done to the rest of the machine and surrounding parts, good luck if you attempt it, sorry
Sep 24, 2007 | Hotpoint WMA54 Front Load Washer
Open Questions:
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
