Question about Ignition System for Kia Forte
2012 Kia forte Koop key in ignition locked in place, will not turn
Purchased car a couple months ago, brand new. This has happened a couple of times previously but was always able to get key to turn. This time key will not turn, I can remove and replace key but will not turn
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
Try pressing on the brake and holding, making sure car is in correct gear.
but pressing on the brake and holding, then try to rotate steering wheel!
Posted on May 21, 2012
6ya staff
SOURCE:
My 2012 kia optima Fob died i replaced the battery but it still wont work unless i put it in the glovebox just to start the car the buttons on the fob doesnt work i only had the car for 2 months.
There is a possibility that your key fob might lost the programming. I suggest that you re-program your key fob, follow the next steps to re-program it.
Instructions
    • 1 Sit in the vehicle and close all the doors. Insert the key into the ignition.
    • 2 Turn the key to the "Off" position then to the "On" position. Repeat this until the door locks cycle to indicate that the programming mode is activated. End with the ignition key in the "On" position.
    • 3 Press the "Unlock" or "Lock" button on the programmable remote. Listen for the doors to lock or unlock to verify successful programming.
    • 4 Turn the ignition key to the "Off" position. Listen for the door locks to cycle to indicate that you have exited the programming mode.
    • 5 Repeat the above steps to add any additional remotes.
Read more : http://www.ehow.com/how_7446180_program-key-fob-kia-optima.html
May 31, 2015 | Kia Optima Cars & Trucks
Why does the 2012 kia forte engine light turn on?
Engine Light Is On: 2010-2013 Kia Forte - What to Do - 2010 ...
www.carcarekiosk.com/...Kia_Forte_EX...engine_light/diagnose
A check engine light can indicate a broad spectrum of problems with your 2010 Kia Forte. ... The video above shows how to locate the on board diagnostics (OBD) plug on your 2010 Forte, how to read the trouble codes and how to reset or clear the checkengine light using a scanner on ...
KIA Check Engine Light (CEL) Codes - Kia Forte Forum : Sedan ...
www.forteforums.com/.../11832-kia-check-engine-light-cel-codes.html
May 20, 2012 - 15 posts - ‎8 authors
Old 05-19-2012, 08:42 PM Thread Starter. SketchedOut ... KIA Check Engine Light(CEL) Codes ... P0115 Engine Coolant Temperature Circuit Malfunction. 2012 Forte Koup: Check Engine light
Jun 29, 2015
Automatic Transmission Shifting Harder Than Usual
Apr 27, 2014
Check Engine Light + P200A code on new 2011 SX
Jun 7, 2011
Oil filter caused check engine light?
Jul 05, 2014 | 2011 Kia Forte
I have a 2006 Kia Sedona. Starting a few months ago, I would turn the key to start and nothing happened. No clicks, nothing. The dash lights would come on like normal while the key was turned. After...
check the clutch start switch or the park neutral switch operations
you need the clutch in to start and there wia switch there that may need adjustment
same for the auto park /neutral switches
check wires
Apr 25, 2017 | Kia Sportage Cars & Trucks
Unlock car without keys
I have 4 dial brass combination lock, and I can not open the lock, how I can set a new combination , the existing combination is not working
Jun 30, 2013 | Locks & Locksmithing
2011 Kia Forte Koup's ignition is sticky and getting worse
Phone the KIA dealership in the area where you live, Ask to talk to some one in the service department, To see what they think would cause it to do that, Most dealerships are verry helpfull, At least where i live in (Canada)
Dec 06, 2012 | 2011 Kia Forte EX
(Ignition) Key won't turn. Happened about a year ago and locksmith WD40'd it, worked fine til about a month ago, key got stuck, I did same (WD40) now the WD40 isn't working and the key won't turn (I also...
graphite is what needs to used on sticky tumblers oils are the worst and causes more problems. you may be able to wiggle the wheel and get the key out. I would put graphite on the new/other key before I inserted into the ignition. Good Luck Tim
Apr 17, 2011 | 2002 Jeep Liberty
95 suburban, ignition locks, can't turn key,
Remove the lower steering column cover and check to see if the rod from the ign. lock and tumbler to the ignition switch is binding up. If it's ok, you're problem may be the bearing under the steering wheel being broken.
Mar 29, 2010 | 1995 GMC Suburban
The key is stuck in the ignition and won't come out. This is the second time this has happened. We replaced the ignition lock cylinder about six months ago to fix it the first time. That time the ignition...
try turning the steering wheel side to side while pulling on the key, the steering wheel will be locked, but just keep trying, it will eventually come out.
Jul 12, 2009 | 1998 Saturn SL
Ignition System for Kia Forte Logo
512 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Cameron Lewis
Cameron Lewis
Level 1 Expert
Kardoc
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
