Open case to clean fan
SOURCE: Opening case
Hi
Check here for an illustration / guide to open OptiPlex SX270 cover.
If you still have problems get back to me
Mike
SOURCE: How to open the case
Go to this link and choose your form factor to get the steps to open up the tower.
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/index.htm
Please rate if the answers your question.
Thanks
Keshey
SOURCE: Can't get the cover off our Dell Optiplex SX270...
See here: Removing the Computer Cover.
Once inside the computer see:Inside Your Computer
Click here to get complete documentation.
SOURCE: how to install 1.5TB hard drive in a dell optiplex
Kindly follow the link below to add new harddrive to the system
http://support.dell.com/support/edocs/systems/opsx270/en/ug/hd.htm#1136008
Thanks for using fixya
proton
Testimonial: "Thank you for the help. Very professional"
SOURCE: error while trying to install windows xp
The most popular Blue Screen of Death error in Windows is the STOP
0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE
BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error)
could mean that there's a serious hardware problem with a hard drive
controller, a driver issue, or even a boot sector virus.
In your case though, this is most likely one of 4 capacitors that are known to blow out on any SX270. Slide the bar at the back of your PC to the remove cover side and look inside for swollen caps. Remove the fans and cpu cover as well and check around there. Replace any bad ones you can find with old caps borrowed from an old motherboard if you have one, or new ones from any decent electronics parts warehouse. This fix has worked for me on every SX270 I have ever had.
