SOURCE: Strato LCD TV DVB1901 Does not
there may be a problem with the smps ....just check whether it is working properly
SOURCE: TP50G90 no power
sounds like something in the standby voltages most likely a regulator or leaky diode causing the problem.
SOURCE: red light blinking on power
this all problem may exist in your tv
1. High voltage problem/ deflection circuit problem.
2. Shorted picture tubes.
3. Problem in the vertical deflection circuit.
4. Problem in the audio ouput circuit.
5. Problem in the convergence circuit.
6. Problem in the power supply regulation.
7. Problem in the portect circuit.
8. The common high voltage arcing that Toshiba sets do at the picture tube.
so for getting pictures gently tap on the side of tv if it works then there may be some loose connection you can fix it by soldering
SOURCE: TV keeps switching on and
Had a feeling it was a blown globe. Found that it was when we pulled it out...now I just have ti find where they sell new ones to replace it. I tried looking on the net from shops to manufacturers and I tell you what...they make it so that you have to call in the professionals so you pay triple the price. I will keep trying though.
Koula
In attempts
to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10
seconds for supply to properly discharge.
While holding down the Menu, Select and Input
buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
