T2742/0310 BATTERY PACK I NEED A CHARGER FOR IT
SOURCE: peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
SOURCE: LIttle Tikes Hummer not working
Sometimes if the battery is not charged up and it sits for a few months then it is difficult to charge the battery. I learned this the hard way by keeping it out all winter without charging up. I called the repair tech's at this website http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
they told me to charge the battery up for 18 hrs at a time, especially if it sat more than 3 weeks.
If the battery is good it may be the foot pedal in this link http://www.shopjandl.com/mepu0001.html
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
