Yes.
1) Laptop OFF, monitor OFF.
Connect a VGA monitor to the VGA port, on the back of the laptop.
The VGA port is on the right side, as you view the back of the laptop.
This is a basic example of a VGA cable, and a VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connector
NOTE* Color does Not matter.
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
Press, and hold down on the Fn key, and at the same time tap once on the F3 key.
No?
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and tap again on the F3 key.
(The Fn key is down at the bottom LEFT corner of the Keyboard.
The F3 key is at the top of the Keyboard.
The F3 key is the Display Toggle-Over key )
Need more information post in a Comment.
Regards,
joecoolvette
SOURCE: Can I upgrade the CPU (T5450) in my Lenovo 3000 Y410 laptop?
Manufacturer
Lenovo
Model
3000 Y410 Series Intel Core 2 Duo T5450 1.66 GHz
System Type
Notebook
Standard Memory
512 (512MB x1 Removable)
Maximum Memory
4 GB
Sockets
Slots/Banks
SOURCE: my Cd dvd drive not working for Lenovo 3000 Y410 Laptop
ur lens is getting weak
pls try this take out the dvd from drive u will see a shiny eye like thing it is lens try to clean it in circular motions with very soft cloth used to clean lcd's and then try those dvd 's otherwise u have to get the drive replaced ur lens is weaken due to some faulty media and excessive use it is a normal wear and tear process
pls rate me fixya for my help
SOURCE: LENOVO 3000 Y410 LAPTOP WIRELESS AND BLUETOOTH NOT
Try reinstalling the drivers for these utilities. Check out lenovo.com for the latest drivers for these.
thanks - billa
SOURCE: Require Audio Driver for Lenovo 3000 N200 type 769 dual-core
I purchased a used lenovo laptop 3000 n200 0769 intel centrino core 2 *** 2\r\nwithout any driver for audio, network, camera, vedio, and other drivers...
from where can I load them
pls. help me
PLS REPLY OR COMMENT. THANKS
