Serial # 26EJ00310
SOURCE: Konica 1015 parts
Try this company. I have used them many of times.
I checked their website and they do carry both parts that you are looking for.
Here is their main website. http://precisionroller.com/
Then on the left side, click "Konica Minolta" then "1015" then click "Fuser Rollers"
and you should find them.
See if this direct link works:
http://precisionroller.com/catalog_display.php?fm=0&step=3&MfrID=297&ModelID=590&CategoryIDs%5B%5D=16
If I have helped you with your question, please remember to post a feedback and a rating.
Good luck.
Mac =)
SOURCE: konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
SOURCE: konica 1015
Add toner.
This will take care of this problem.
Please post a rating if I have helped you.
Any more questions, please post again.
Thanks
SOURCE: Konica 1015 copier with image ghosting problem
I hope the correct toner is in there.
It could be that the cleaning blade on the drum isn't working or the charge isn't working right.
SOURCE: konica copier 1015 copies come out black what is
The exposure lamp (light source) that illuminates the original has failed.
This may be fused in your machine but the fuse rarely blows without reason.
You should be able to verify this pretty easily by lifting the cover and doing a blank copy.
