Question about Simplicity Creative Spirti PLus SA2200 Mechanical Sewing Machine
The needle will go up and down if I crank the wheel by hand. But whenever you go to push on the power pedal, all you get is a slipping belt noise. Was working with a heavier fabric when the needle got stuck in down position. Now the belt just seems to be loose. Need to know how to access belt area. Instruction manual has nothing about belts.
Here's a You Tube video that should help. https://youtu.be/8Voq7f5vT6E
Posted on Oct 24, 2017
SOURCE: I live overseas, and brought this sewing machine
its not transformer or machine problem at all.all the connections are also proper.its the power issue the required power to the machine is not getting from the electric outlet.just call the local electrician and check out the power supply voltage from the electric outlet.and power required to the machine which will be listed on the machine.if more power is required he will connect the over power IC and get the machine work.if less power is required he will connect the RESISTOR and lower the power to the machine and make it work.
Posted on Aug 30, 2009
SOURCE: threading instruction for model #1220 simplicity
http://www.sewingstyle.com/Simplicity-Sewing-Manuals.htmlnot
not sure if you have the manual, try this site for a manual,
Posted on Sep 03, 2009
SOURCE: not completly threading or something
i was told this is a timing problem
Posted on Mar 26, 2010
SOURCE: I have a Simplicity Denim
Hi. I believe your machine has a snap-on pressure foot. I've posted pictures of snap-on pressure feet at www.robbiesews.blogspot.com; just look for the 'pressure foot' tag or search the site for pressure feet and you shouldn't have any problem finding that post.
Anyway, there is an adapter (called an 'ankle') at the end of the 'long iron piece that lowers and raises the foot' (excellent description, BTW). The ankle attaches to that piece with a small thumb screw. With the ankle in place, you just lower the ankle onto the catch on the pressure foot.
You can also use regular low-shank feet on your machine. First, remove the ankle. The regular low-shank feet will attach to the raiser bar with that same thumb screw that holds the ankle in place.
You really should get a replacement manual for your machine. I found manuals for Simplicity sewing machines at http://www.sewingpartsonline.com/simplicity-sewing-machine-instruction-manuals.aspx.
Hope this helps!
Robbie
Posted on Aug 13, 2010
SOURCE: Need To know wher I
You can get the manual on the link below. scrool down to product details then click on the product manual.
http://www.amazon.com/Simplicity-SA2200-Creative-45-Stitch-Function/dp/B0000648AG
Good luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 17, 2010
Feb 03, 2016 | Brother Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Mar 21, 2015 | Sewing Machines
Oct 27, 2014 | Sewing Machines
Jan 02, 2014 | Singer Inspiration 4206
Dec 24, 2013 | Simplicity Sewing Machines
Mar 09, 2013 | Sewing Machines
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
Jun 26, 2011 | Simplicity Sewing Machines
Sep 19, 2009 | Singer 7444 Mechanical Sewing Machine
511 people viewed this question
