You can get the Blackberry Torch 9800 Model Network Unlock code from Mobile-unlocker.com/blackberry-9800-torch/rs2wp9/ and Unlock it easily.To enter the code follow the instructions below and unlock it step by step....
Blackberry Unlocking Instructions for Torch 9800:
Warning : Do not enter any wrong unlock
codes on your Blackberry 9800 Torch mobile phones. If you enter over a
certain amount of wrong unlock codes on your Blackberry 9800 Torch
mobile phone, your phone may get hard locked and sometimes become
unusable.1 - Switch ON your Blackberry 9800 Torch with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 9800 Torch should then be unlocked.
SOURCE: How to unlock BlackBerry Torch 9800 .
As you have not specified which code you need i am hereby giving how to get all of the codes:
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer caredepartment.It is free of cost.
Therestrictioncodecan
be got from your old service provider..This restriction code iskeptto
prevent someone who stole themobile from using it withanotherprovider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost donot pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above proceudre works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If
you try pin more than few predefined no of times your phone will ask
PUK code which can also be given only by your service provider which is
specific for each and every mobile number . Do not try PUK(new pin code)
code many times or else your sim will be blocked and you will need a
new sim.
There
SECURITY CODE:
If
it is lost nothing can be done. You need to flash your mobile at an
authorised service centre which will reset the mobile memory and also
all the data inside the mobile will be lost.
SOURCE: Blackberry torch (9800) messenger crashes
likely low application memory, try a battery pull,
SOURCE: my blackberry torch 9800 has 0 mep attempt left
Blackberry solution for mep code (0 left)
This is the solution for anyone have mep code 0 left in his handset that no attemt balance for enter code.
1. Please install black berry desktop manager. (its free download from black berry website)
2. Connect handset with pc.
3. Open this software its shows booting rom and ask u phone unlock code(note: its not asking mep code just user code).if not phone code inserted then it update rom automatically.
4. Now your handset reboot, then you got mep code(10 left) in network lock section.
Download Rom Booter:
RapidShare: Rom Booter
After you will need a unlock code to unlock your Blackberry cell phone,you can get unlock code at cheapest rate by BLACKBERRY TORCH 9800 UNLOCK CODE provider.
SOURCE: is there anyway to unlock
I would advice you to take your mobile to a mobile shop and set it on grand reset. After that, you would have 10 attempts again. Then you can unlock your mobile from Blackberry Unlocking Codes with IMEI to get reliable and CHEAPER code. They are very friendly and provides good customer support service. I hope it would be helpful for you as well :)
SOURCE: how do i unlock a
When a cell phone gets hard locked, it usually is difficult to get unlocked again, but its possible and you can get it unlocked from a good cell repair shop. After then, you would get 10 attempts to unlock your cellphone again. Then you may get Blackberry Torch 9800 unlocked from Blackberry unlocking codes with IMEI. They provide very CHEAPER rates.
