Model wtw57esvw0
SOURCE: GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
SOURCE: Washing maching not filling with water
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine.
(The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
SOURCE: My maytag washing machine spins but won't agitate.
sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
SOURCE: won't spin won't agitate
http://www.repairclinic.com/Appliance-Parts?s=t-110.24722300-%3d%3d
This is a link showing the part I suspect needs replacing in your washer. It's the motor coupler -- when it breaks, nothing turns but the motor itself.
SOURCE: whirlpool Model: WTW57ESVW0 will not
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
