The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn
on the device you want to program into your remote, for example if you
are programming your remote to control your TV, then turn on the TV.
2) Press and hold the
device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press
OK. Release both buttons. The mode buttons blink twice.
3) Press
922.
4) Point the remote control toward the device you are setting up and press the upper part of the
Play button.
5) Press the
Fast Forward button. If the device you are setting up does not turn off, keep pressing the
Fast Forward button until the device powers off. (You can use the
Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press
OK to assign the code in your remote control.
Note:
There
are over 200 possible combinations for TV and DVD codes. The most
common codes are tried first but you may still need to press the Fast
Forward or Rewind buttons over 200 times to find the correct code for
your device.
If you reach the end of the list of codes, the
entire remote flashes twice and returns to normal operation. You can
exit programming at any time by pressing the Exit button.Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
- Turn
Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
- Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
The lights for each device button light up and the light for the device button you selected remains on.
- Press the Power button on your remote.
The device button blinks three times then turns off.
- Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
Did the device turn off?
Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a
Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
- Turn
- Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
- Press 991.
The mode button blinks twice.
- Point the remote control toward the device you are setting up and press the Play button.
The
remote control tests each code in its library. The mode button blinks
once each time the remote transmits a new code. When the last code is
reached, the mode button blinks twice.
- When the device powers off, press the Select button.
- Verify the new code is correct by pressing the Power button.
Did the device power on again?
Yes: Press Select to assign the code in your remote control.
No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
