I had the same problem after only a few months. There is a float at the side of the water resivour, this float also has a magnet attached to it and for some reason becomes lodged at the bottom of the tank, telling the machine that there is not enough water in the tank, even when there is. Use a magnet on the outside of the resviour, connect it to the one on the inside and lift very slowly upwards...Hey presto the light stops flashing and the water boils
I had the same problem - my husband discovered that there is a magnet inside the water tank which floats when the tank is filled. The magnet turns on a switch in the machine when the reservoiur is full. However, the magnet in ours was stuck at the bottom even when the tank was full, so the machine thought the tank was always empty! This probably happened due to a built up of limescale. I bought a new tank from Amazon and the problem was thus solved without having to buy a new machine. I shall try and descale the tank and then I'll have a spare.
I have a problem. The water is not boals, what will be the problem. Thanks
I also had the same problem. I didn't take my machine apart, though. I just filled the reservoir, and noticed that the float wasn't moving. So I emptied it, tapped it on the side of the sink, and now it's floating again. Try that first-save money and frustration! (And keep a french press on hand for emergencies!)
I had the same problem. When i tilted the water container back it would heat the water but once fully inserted it was blinking like there was no water present. I disassembled the back of the coffee maker and checked out the water level sensor. That was working ok. Then I tried using the magnet in the water container to check the sensor which was also ok. Then i noticed that once water was inserted into the water canister the float (level float)did not move, So there is the problem. I then just bridged the water level sensor and the machine is working again. the only setback is that I now have to make sure there is enough water in the tank as otherwise the pump will run dry and burn out.
my maker will not heat the water either, it just sits there with a flashing light! but it does change if there isnt enough water ....
dunno can canyone help
MY NEW SENSEO ISNT HEATING WATER AND RED LIGHT KEEPS FLASHING ??
light indicater wont stop flashing and water wont boil? anyone have solutions not used it yet. its brand new
this coffee maker is a heap of ****.. i have the same problem lol
same problem, i have flushed machine through as per the instructins but still no water coming through to make my much wanted coffee!!!
I have the smae problem. After a year of use and looking after my machine it will not now heat the water unless I tilt the resovoir back slightly, then when I put back to the correct place after heating the water the red light flashes agin!
