Sharp 25L-S100 25" TV Logo
Harry Rothstein Posted on Dec 27, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BLack box in the middle of my screen?
When you turn on the TV, the picture is good for 3-5 seconds. Then a Black box appears and covers the middle of the tv on down. If you change the channel, turn up the volume, go to the menu, etc. it clears up and then black box reappears. Is there a way I can fix this without taking it somewhere? Thanks, Harry
  • Anonymous Mar 16, 2014
    volume goes silent or goes to maximum when we want it to stay in the middle. also, words appear on screen randomly, like "volume" ... "menu" etc.. i don't use a remote at all. usually when i manually adjust the volume, it does go to my desired volume level. other times the volume can not be changed at all. can't watch anything like this.
  • Anonymous Mar 26, 2014
    the tv has no sound but a picture and there are 4 number 2's on the screen with a letter code in the middle of the screen- no black box.
Anonymous
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Dec 27, 2006
Anonymous
Expert
Level 2:
Scholar:
Answers
119
Questions
0
Helped
54314
Points
184
Iv'e run into this before, you have closed caption text 1,2,3 or 4 on. this is different than the normal "cc" cation. just go into your menu & turn off closed caption.
6helpful
There is a black empty box in the middle of my TV
use your remote to go to your closed caption settings and shut off the 'text'.
15helpful
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
16helpful
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
5helpful
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
1helpful
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
22helpful
7answers
Black box in the middle of my mitsubishi tv
This is a common problem, some how you have the closed caption on and turned to the text mode. So to fix this scoll through the tv's menu and find the closed caption and tur it back off
Ilo picture problem
turn off the closed caption Sounds like it's in text mode
good luck
Sue, Hitone tv, Baldwin NY
2answers
Our TV reset itsself to sales pitch
1) Demo mode clears by holding vol up & chan up at the same time at the set front buttons. Or try menu & power.......
2) Black box is called a text box = part of closed-caption option.
Select CC to turn text box off.........
Note:Always provide Model # , Chassis # and age......
serial # not needed / helpful..........T.
8helpful
You have CC (closed captioning) turned on and it is set to text mode.....Go to the menu on the remote use the right arrow and hilight "C.CAPT",use the down arrow to highlight "C.CAPT",use the right arrow and highlight "off" then exit button on remote.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
