Camera works perfect on A/C. No problems.
Camera works perfect on battery (or A/C) on video.
But press the shutter button and all goes dead. Lense stays out and won't retract until plugged into A/C again.
Something seems to disconnect the battery once you press that shutter button. If you don't press that button, it stays on, all buttons work and (again) you can take video.
Any thoughts?
Stumped in Idaho
Hold the power button in the ON position for 10 seconds, then release (obviously making sure the batteries are in first). This forces the camera to do a full reset - you will have to set the time etc when it restarts.
Hope this helps, it worked for me...
If the camera works on A/C then you need to replace the battery. If you suspect that the connection is lost when you push the shutter, try to remove and reinsert the battery. If it works, make sure that battery connectors are clean.
Thanks, Mark. I just tried that and it worked! I replaced the camera a while back but still had it and just now tried that. Great tip! Thanks, again.
