SOURCE: i have a printer dcp 7030 brother company i am
I just had this problem and fixed it. The original toner cartridge that comes with the printer cannot be reset. You have to buy at least one new cartridge. The reason is that the original cartridge that comes with the printer doesn't have a reset flag. You can, however, refill/reset a cartridge that you buy separately. Pull out the drum and lift the cartridge out of the drum. Hold the handle and look on the left end. You should see a crescent shaped hole with a white flag/lever. To reset this, move the white flag all the way to the left (I had to use something to push it). Put it back into the printer and voila - it fixes itself. Then, after the printer has been reset, you can use the original cartridge again, if you want. The flag part won't matter once the printer has been reset. I hope this is clear. I know it worked for me, and I had the exact same problem.
SOURCE: brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
SOURCE: I am facing problem in brother printer DCP 7010 is
nvr mind, i guess the toner is exhausting or is exhausted..
mind for a refill or head change or both..it may solve ur problem..!!
do contact ur system admin!!
SOURCE: Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
SOURCE: i have dcp-7030 brother printer.
I know how to solve drum end problem along with change tonner.... Send me mail on [email protected]... Thanks
