SOURCE: i have already this message : press ESC to access Startup menu.
You should have the option to press either f2 or f12 to go in to bios
SOURCE: Cannot wake up my laptop elitebook
Press the power button for some seconds so that your laptop shuts down. Then try to start it again.
SOURCE: Start up error
ure your windows disk, boot with it.
boot into recovery console, type in your username and password then type in chkdsk /p
SOURCE: HP Compaq 6370s start-up problem. Can't
Go to the BIOS window by pressing the escape key. See if your hard disk is being detected. If not, then you need to remove the hard disk and see whether the operating system is intact or not. Try changing the boot sequence and booting from a USB device and then changing directories to see the hard disk contents. If you can see the hard disk, then you may have to repair your windows installation with a windows boot CD. Tell me if this solution helped you and if not, I may be able to give you some more tips to fixing this problem.
SOURCE: when i switch on of
configure your CMOS settings..on the boot manager.check on the first book if your hard drive is in the first boot.
Testimonial: "thanks"
