It is very important that i get an answer as soon as possible! Thank you for looking and trying to answer back a soon as possible.
SOURCE: set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
SOURCE: how to fix nat on xbox live
NAT rating can be remedied by either turning on UPnP on your router, DMZ or portforwarding. This site has some good guides on how to improve your NAT rating when connected wirelessly to xbox live:
How to connect wirelessly to xbox live with open NAT
SOURCE: change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
SOURCE: how do i change strict nat to open with a ZyLEX
To change your NAT into open, you need to open some port. That's done using port forwarding feature of your router. Go to www.portforward.com for instructions on how to do it.
SOURCE: i need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
