i-mate K-jam Smartphone Logo
Posted on May 15, 2012
While connectinng to the gprs with my idea network it showing as no modem found for above number
Plz helpo me to solve this problem
nikkilalit_j
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 18, 2012
nikkilalit_j
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
66
Points
Plz call idea customer care ...
1helpful
HI CAN I USE SIM CARD FROM MY PHONE TALK TALK MOBILE AND USE IN MY ASPIRE ONE
Hi,as far as I know your ACER does not have a SIM card slot thus not capable 3G Data / GPRS connection..however if you have or obtain a
"USB GSM GPRS EDGE Modem for Internet
yes you can..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
What is USB GSM modem?
USB GSM modem is a modem working for cellular gsm networks.
USB GSM modem contains usb gprs modem and usb edge modem.
It's a USB internet modem. Simply speaking, it's just for internet connection.
Normally, we can call GSM modem a 2g modem, GPRS modem for 2.5g modem, and EDGE modem for 2.75g modem.
USB GSM GPRS modem works with GPRS network, back compatible to GSM network.
USB GSM EDGE modem works with EDGE, GPRS and GSM networks, providing 384kbps internet data speed.
http://www.szelins.com/USB_GPRS_EDGE_Internet_Modem.html
Modem removed and unavailable device com1
First of all uninstall and unpluged your modem then reinstall your modem without attach it. After installing you should attach it or plug it and if required during installation you should plug it during installation.
Now create connection and run it. It will work properly.
Good Luck
1helpful
2answers
Can't add new gprs account in nokia 6085
I think that the personal config settings are either in their own memory block, or they are saved on the SIM card.
39helpful
16answers
I have idea netsetter huawei EG162G MODEM its work with idea sim only can some unlock its to use other operator its imei no is 353474027400605 and sreril no is D82AA12921300854 PLZ REPLY THANKS
EG162G usb modem.my IMEI no is: 353474027386069 & s.no.: D82AA10921300899. i have idea net setter HUAWEI. but i want to use other network. but when i put ohter sim card so ask 10 digite unlock code. please help me and give me code for unlock it.
1helpful
2answers
Problem setting up lightwave usb gprs/gsm modem
I use lightwave gprsmodem call me on this no i will tell you what to do>08037192147
Phw acess gprs on htc p3400i
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
65helpful
8answers
GPRS/MMS settings on HTC P3400i for vodafone postpaid connection
After browsing a lot of sites and experimenting with the settings finally I was able to configure my HTC P3400i with Vodafone Live support without any help from the Vodafone customer care (who were very bad and rude when I called them for getting the setting). The settings is working fine for me in Bangalore. Hope this helps all who bought this phone and struggling for getting the GPRS setting for HTC P3400i.
Below is the step by step instruction:
Step 1
Start->Settings->Connections->Tasks->Add a new modem connection:
Enter a name for the connection:
<give any name>
Select a modem:
Cellular Line(GPRS)
click next
Acess point name:
portalnmms
User name: <blank>
Password: <blank>
Domain:* <blank>
Go to Advanced->TCP/IP
select radio button "Use server-assigned IP address"
Go to Advanced->Servers
select radio buttion "Use server-assigned address"
Step 2
Start->Settings->Connections->Tasks->add proxy setting
Select "This network connects to the Internet"
Select "This network uses a proxy server to connect to the Internet"
Click "Advanced" button
Tap on HTTP
Server: 10.10.1.100 Port:9401
Username: <blank>
Password: <blank>
Domain: <blank>
Tap on WAP
Username: <blank>
Password: <blank>
Domain: <blank>
Step3:
Start->Settings->Connections->Advanced
In "Select which networks are automatically used"-> click the Select Networks
Programs that automatically connect to the Internet should connect using:
Select the Connection name which you configured in Step 1
Programs that automatically connect to a private network should connect using:
Make sure you reboot after doing above change.
1helpful
6answers
MOTOROLA W230
I HAVE SOLVED THIS PROBLEM. before installing this driver uninstall all motorolla driver. and install only charging driver.
after then install the driver file named 'moto_w230_gprs.inf' (available on internet) on same port on which charging driver is installed yhen write the code" AT+CGDCONT=1,"IP","INTERNET" in extra initialization string on modem. (internet is access point network) use another if u have other networks
set the baud rate of ur modem 230kbps
write the user name andf password
and fone number '+cgdata' without quotes and then try
i have cheked on telenor pakistan its working fine
Best Regards
Engr. Tarique R. Memon
6helpful
6answers
Unable to use gprs in Motorokr E6
hi, i am unable to use gprs in motorokr E6.i m using vodafone connection and GPRS is already activated on my cell form customer care.i tried a lot wid all the settings sent by customer care but it didn't work.plz tell me the possible settings/solution to use GPRS
23helpful
7answers
Gprs settings
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet
Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!!
9448834529
Top i-mate Computers & Internet Experts
ExpressFiX
ExpressFiX
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
