This is a BRAND NEW player it has sound and plays DVD but there is no picture. What is wrong with it? Please help! Thanks!
SOURCE: JVC DVD player plays with distorted sound
Do you run your volume flat out? If you do then perhaps you've damaged the cones in your speakers. Some of these 5.1 speaker systems are utter rubbish. They look nice but the speakers are often garbage. Also running speakers at high volume for lengthy periods can overheat the coils and distort the cones.
SOURCE: I have a Samsung DVD-R 120
Exactly the same problem with mine. I even went shopping today after months of buying dvds that wouldn't play, to buy a new player. I then had a silly revelation. I pressed open and with a tight grip on a cotton bud I swept all that I could reach within the recorder. Can you believe it but it worked. Now I have my multiregion back and it has so far played all of the PAL 2 and PAL 4 dvds that I have bought since the PSO came on months ago. I don't what the problem was or if this is relative to your problem but I wanted to let you know....
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
SOURCE: cant get color picture when playing DVD's
did you check using another dvd with a colour movie in it
and check if anyother shows running in tv is also in black and white or it shows colours
if nothig helps then you have to replace the tv picture tube or the cd player lens
thank you
