Showed a UE error. Where can I get a manuel.
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
SOURCE: LG front Loader Intellowasher 7kg WD-8015c has
If this has a mechanical timer, the clock drive gears may have a damaged tooth or a piece of debris is blocking further turning of the dial. If electronic, the control unit should be replaced.
SOURCE: Error Message and Tub not spinning
Depending on how many clothes are in the washer you may a unbalance error
SOURCE: lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
SOURCE: Please help! My samsung 7kg J845 front loader
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
SOURCE: 7KG WD-8050FH LG Clean Master
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Yes the solution was very helpfull. I would still like to know where I could get a user manual for this machine?
www.manualsonline.com or www.searspartsdirect.com
