Hooked dvd player up now trying to get back to tv
SOURCE: RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
SOURCE: Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
SOURCE: dvd player hook up
If the make and model number of your TV is as stated in the category posted. RCA model 27F530T 27" then you can find the owners manual at the following link.
http://tv.rca.com/RCATV/Assets/pdfs/27F530T_1620181B_IB_e-04.pdf
SOURCE: cannot tape on vcr with new dvd-vcr player
You need to route the signal from the cable modulator to the DVR and then to the TV to be able to view and record. If this is done you will be able to watch what you are recording. When you are not recording, the signal will go through the DVR to the TV.
Please change the cabling and you should have what you want.
