If is not liquid cooled then u have water in the gas wich is common with being stored where theres condensation.if it is liquid cooled it can be head gasket,cracked head or cylinder....
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
