DeBruce Polish will remove these problems on both stainless steel and enamel finishes. DeBruce Polish also works wonderfully on ceramic cook tops. DeBruce Polish is non-toxic, odor-less and non--abrasive, a true eco-friendly multi-surface cleaner. We get DeBruce Polish at debrucepolish.com.
Never Ever use cleaning cycles. 8 times out of 10 they break things, oven elements, door catches and even circuit boards. You will need a service visit. click here
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
To
close an oven door when it's in the locked position and the door is
open, press and hold the oven door light switch while following these
simple steps:
Program the oven to self-clean.
Wait 20 seconds.
Cancel self-clean.
Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
Remove the oven racks.
Set your oven control to "Clean."
Select a cleaning time or choose a cleaning level:
light, medium or heavy. For typical cleaning needs, we recommend that
you select a cleaning time of three hours or choose the medium setting.
Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until
the oven cools down. When it is sufficiently cool, the door will
automatically unlock.
Without a model number, I'm shooting in the dark but I'll give you basic instructions that fit for most ovens, OK?
First off the door has to be locked PRIOR to cleaning. Look around the top of the oven door, there should be a handle (for mechanical models). Rotate this handle from the left to the right to lock it. If there's no handle, that means your oven locks the door by itself when "Clean Mode" is selected.
Now, at the control panel, select "Clean". At this point, you may have options on the length of time it should clean, select 3 hours and hit "Start".
There ya go! Hope this helps. If not, DON'T RATE THIS SOLUTION! Just write back and provide the model number, I'll give you exact instructions with that. Deal? Cool.
Perhaps the door gasket is not sealing well enough. In self clean mode the oven get very hot and vaporizes the fat off the sides. With a leak I think some of the fat is redepositing on on the outside where the leak is. You may need a new door seal.
I was wrong (I think). the baking element probably was burnt out as the repairman said. He replaced it and I thought selfclean still wasn't working. In fact, I think I just had to give the self-clean function more time. Also, I was judging by smell. We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair. Bottom line, the oven was clean after the baking element was replaced, sans smell.
