Car Audio & Video Logo
Shannon Posted on Apr 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear Entertainment Systems plays sound on right side only
My DVD player plays great and has worked well for 4 years. All of a sudden, I get no sound from the left side when playing DVD movies. It is the same when using the radio, wireless headphones, or headphone jack on the side of the unit. If I turn the volume way up, I hear the audio through the left but it is very soft with a lot of static. Would this be a part failure within the unit, or has something been changed some way in the setup? I have checked and rechecked the connections. The only wires used are for the dome light and power(red/blk trace, blk/red trace, red, and black) It is meant to work wireless only.
  • Shannon May 16, 2012
    Could it be a problem with the FM modulator?
    My thought is that there is an issue with the FM modulator. Is there a way to test it?
Marvin
Level 3:
Top Expert:
  • Audiovox Master 85,242 Answers
  • Posted on Apr 13, 2017
Marvin
Audiovox Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29023465
Points
266281
Using the wiring colors check the head unit output with a test speaker.
2 Related Answers
Anonymous
  • 155 Answers
  • Posted on Apr 24, 2009
SOURCE: No green On/Off light. Charge light is red. I hear only static.
Two things.. Check the batteries..
Also.. since these headphones have to have a signal sent to them to activate transmission (green light simply indicates they are receiving a signal) it can take a few moments after the signal begins to activate them.
I would hazard a guess that when you unplug the cables and then plug them back in.. the feedback that generates activates the base much the same as a regular audio signal would
Finally.. make sure the source is a fixed output.. if not.. and its variable..you will have to increase the output or volume to activate the base..
Anonymous
  • Posted on May 19, 2009
SOURCE: How do you get the sound to play from headphones only and listen to radio while dvd is playing?
Just press FM button. Blue Light turn off, and you can listen radio without interference. Gustavo (Alpine Buenos Aires)
2018 Honda Odyssey. The DVD is not working?
Question edited for clarity and add maker.
Question moved to model category.
It may need repairing but there is a setting to disable it.
Problems with 2018 odyssey DVD player. : r/HondaOdyssey
Reddit https://www.reddit.com > comments > txddq7 > proble...
Apr 6, 2022 - We have been going through the most ridiculous and annoying process with Honda regarding our 2018 Honda Odyssey DVD player. It just stopped
Faulty infotainment center! : r/HondaOdyssey - Reddit
Dec 19, 2019
2018 Odyssey Blu-ray drive replacement : r/HondaOdyssey
Dec 1, 2021
2018 Honda Odyssey: Repeated failures with CabinWatch ...
Feb 15, 2019
2018 Honda Odyssey DVD player issue - sound but nothing ...
May 25, 2022
More results from www.reddit.com
2018 Odyssey Rear entertainment overhead screen not ...
Honda Odyssey Forum https://www.odyclub.com > ... > 2018+ Odyssey
Jan 25, 2020 - The DVD continues to play; audio works fine. The only thing that isn't working is the overhead screen. Does anyone know if there is a fuse ...
The rear entertainment screen is not displaying the image
JustAnswer https://www.justanswer.com > Honda Questions
Jul 8, 2021 - The rear entertainment screen is not displaying the image from the DVD player. Sound for video is working however.
1 answer · Top answer: Hello, thank you for the question. The first step is to eliminate the possibility of a fuse ...
2018 honda odyssey rear entertainment system not working!
Apr 19, 2023 - 2018 honda odyssey rear entertainment system not working! Just a black screen. It's been dead for a couple of weeks I.
Why is my 2019 honda odyssey rear entertainment system ...
Vehicle History https://www.vehiclehistory.com > questions > why-is-...
Apr 10, 2020 - Some of the most common reasons Your 2019 Honda Odyssey rear entertainment system might not be working are that You may have power disabled ... ..
HOW DO I FIX MY CENTER SPEAKER
Rear and center speakers not working - Tom's Guide
www.tomsguide.com/answers/id.../rear-center-speakers-working.html
Sep 4, 2013 - Hey guys. I bought a Sony DVD Home Theatre System DAV-TZ140 about a year ago.And it worked perfectly, but all of a sudden my center and ...
Audio Troubleshooting 101: Getting Your A/V System ...
www.audioholics.com > Home Theater Setup > Home Theater Calibration
Jul 14, 2009 - Audio Video Troubleshooting 101: Get your AV System Working Again. ... It's time to put on your propeller head and get down to the business of fixing your system and enjoying it to its ... Problem: One or more of my speakers isn't working ... your Blu-ray player to your AVR and let the played do the decoding.
Tips for fixing common sound problems - Windows Help
windows.microsoft.com/.../tips-fixing-common-soun...
Microsoft Windows
I have a samsung surround sound entertainment system. Wen i play my dvds all i hear is back ground music an sound effects but not the people talkn. Iv checked to see if the spealers was hooked up right.
hi try to check the RCA connector connected to the player . and check if the audio settings
is properly configured.
you can check by going to the audio settings of the dvd player
How do i change the unsupported format to play a dvd
DVD players have 5 regions. And on the back of every DVD you buy the region code is marked in side a circle ( like a globe ).
Region 1 is North America
Region 2 is Europe . Middle East & South Africa
Region 3 is South East Asia,
Region 4 is South America, Mexico, Australia
Region 5 is India , USSR, Africa.
To change the region code of your Lifestyle 38 DVD player follow the steps given below.
Make sure you familiarize yourself with the buttons on the remote and not fumble while keying in the sequence given below.
Make sure there is no disc in the tray of the player and it is closed ( tray ).
First step - Press RIGHT arrow, UP arrow, SHUFFLE, STOP, MUTE
To change to a specific region code
Step two --- Open the disc tray
Step three --Press STOP
Step four --- Press SHUFFLE
Step five ---. Press # key for desired region from the list given above.
Step six ---- Press ENTER.
Turn off the DVD player wait for a 10 seconds and restart. It should work.
Enjoy your foreign DVD's. Cheers!!.
Does the 2005 GX470 Lexus play mp3 files?
Audio & Entertainment Audio System Lexus Premium Sound System with Automatic Sound Levelizer (ASL) and in-dash, six-disc CD auto-changer Speakers 11 Audio System Mark Levinson® [3] Premium Audio System with Automatic Sound Levelizer (ASL) and six-disc DVD/CD auto-changer Optional
Speakers 14 Optional
Watts 240 @ 0.01% THD, 20-20,000Hz [21] Optional
MP3 Audio Input Plug MP3 audio input plug Rear Audio Rear-Seat Audio System (RSAS) Optional
Antenna In-glass antenna with FM-diversity system Satellite Radio XM® Satellite Radio capability [22] Optional
DVD Entertainment System Lexus DVD Rear-Seat Entertainment System (RSES) Optional
Wireless Headphones Included with DVD Rear-Seat Entertainment System (RSES) [23] Optional
http://www.lexus.com/cpo/model_library/GX/2007.html Wheen you click this link scroll to the bottom of the page. It will be under Audio & Entertainment.
I have a jensen vm9512 that I can't get the rear zone sound to work
i installed a rear monitor where my rear entertainment was and i just unplugged the unit. this caused no sound in the rear speakers. all i did was hook up the rear entertainment and put it somewhere out of the way. this is a possible solution.
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
1helpful
2answers
The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
-Ed
2answers
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
