My tv red light won't come on, although the plug fuse to TV is ok and the remote control battery has been replaced. Serial No. 101MAZV 7R 437 production code 42P J550 ZOBEK LLJP Manifactured 2011 January
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
SOURCE: LG42PC3D TV - No remote control. Manual control works.
dont blame the receiver yet, the problem mostly comes from the remote control. it may be the infrared emiting problem. checkout if the infrared in the remote control is emited well. to see this infrared you can read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
good luck
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
aFTER TRYING THE SOLUTIONS (1) THE RED LIGHT ON THE SET STILL REMAIN THE SAME
aFTER TRYING THE (1) SOLUTIONS THE PROBLEM REMAIN THE SAME
