I have a Whirlpool 6wmv43ns/02 430ltr Full Size Fridge/Freezer. The temp control doesnt seem to work as even in the min position the fridge is freezing food. Any Idea's what the problem is? Thx M
it sounds like the thermostat. but check the defrosthing element also
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
SOURCE: my frdge compartment is freezing
Pehaps the damper door motor is burned out or the damper door is just stuck open causing to much air to flow into fridge side. Damper door is located at the very most top-back-left corner of the "fridge" side.... goodluck...
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
SOURCE: fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
