I need to download a manual
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
SOURCE: need manual so I can update and use stored numbers
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
SOURCE: model 29578be1-a need manual
Well you can please follow the below link to get the manual -
http://www.retrevo.com/support/GE-29578BE1-Telephones-manual/id/18378bh351/t/2/
Good Luck!! Thanks for using FixYa
SOURCE: lost the manual how do I store phone numbers
Press STORE button, LOCATION? shows in display, press the memory location (0 to 9 or quick buttons A to C) then press STORE button again. Dial the number you wish to store and then press STORE again. Use the number keys to enter the name of the person you have just stored and press STORE again. I hope this was useful.
