Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
SOURCE: toshiba satellite L300 wont boot
hi thanks for using fixya!
I suggest that if you could do a full scan (anti-virus) to your system. Then, do the disk defragmenter on all your drives, especially the system drive.
the last option is to reformat your system/laptop.
If you need further assistance, let me know.
pls rate me positively! thanks!
SOURCE: Set my Toshiba Satellite Laptop PSA60U-01W015 to it Factory Sett?
some of these systems have the factory restore option on post boot before the OS kicks in. From a cold boot look for the hit DEL or Fx key and do that - you may have to boot a few times to catch it, and possibly hold the defined key down in anticipation of the option to appear on what looks like a DOS screen. You may need the recovery discs that came wit the system if the image is not in a hidden partition of your drive. Good luck.
SOURCE: toshiba satellite m305d problem restarting
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
32
SOURCE: webcam driver open failed chicony 2.0
ur webcam driver is not suitable for win. 7
plz try it to install in program compatibilty mode
SOURCE: WEBCAM DRIVER OPEN FAIL. Toshiba M300 satellite
Go here and download the driver utility for your webcam.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2228766&rpn=PSMD8U&modelFilter=M300-ST3402&selCategory=3&selFamily=1073768663
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Restart the laptop and try logging back in using the new password.
Log on without the Windows XP installer. If you don't have a Windows bootable CD, use another computer with internet access so you can create an emergency recovery disk (ERD) that will allow you to unlock a Toshiba laptop. Browse through the internet and search for ERD software.
Burn the ERD program into the blank CD and use it to reboot the Toshiba laptop that you want to unlock. The computer will automatically detect the program, so it will take you to a series of prompts where you can change your password.
