The following resistors need to be replaced but I'm uncertain what the values are supposed to be. RK58, RK50, RK54 and RK42, I'm also going to replace the 2 STK392-120's. Thank you I have repaired a convergence issue with a similar Hitachi rear projection tv, but I need to make sure I have the appropriate values for this convergence board. Thank you
I don't think it will hurt especially if the updated manual indicates it.
Testimonial: "Thank you Phil, I appreciate the input."
SOURCE: Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
SOURCE: 65xwx20b
i need value for RK62, resistor burnt and cant see colors. on DP2X board 57SWX20B near the green STK connector.
SOURCE: Incorrect resistors on DP1X PWB?
If your tv is a 43uwx10b the original values of the resister are correct it is a DP14G chassis do not change the values
SOURCE: i need the resistor values for RK42, RK46, RK50,
If it is 53uwx10B:
RK42 2.2 OHM 1 WATT
RK46 1.5 OHM 1 WATT
RK50 2.2 OHM 1 WATT
RK54 1.5 OHM 1 WATT
RK58 2.7 OHM 1 WATT
RK62 1.8 OHM 1 WATT
Double check the numbers on the STK chips as most of these sets use STK-392-110 OR 392-150 CHIPS-----ONLY A FEW OTHER MODELS(MOST 43 INCH USE THE 120 CHIP.)
I do this here for free so if this helps you take just a minute and give me a vote here.
If you have any questions or need help reply to this posting here--I am here to help people.
REGARDS, SD TECH
Testimonial: "thanks for the quick response and info. it was helpful."
SOURCE: Hitachi 43uwx10b. How do i test resistors for
You have all the resistor are correct! Yes I can Tell you exactly what you need to know and How to Save settings after you adjust convergence, I have to pull out my manual on your hand unit Be right back. first you need to go to front of TV remove front bottom panel to where you can see the front of chassis on the board you replaced ICs there is a small blue contact button with TV on press and hold for 5secs Convergence Pattern should appear! You will need your hand unit to begin to adjust convergences.
Testimonial: "Your information was helpful but did not solve all of my problem."
Also the Wattage values would be appreciated, I was thinking 1W for them ?? They are fire resist
I now have the service manual and currently deciding whether to install the newer upgraded resistor values or the original values from the service manual. Because the manual is an updated copy it has the update with the original scratched out, but you can still read the value so I'm not certain whether or not to use the updated resistor list and install all new resistors to match the new schematic or go with the original scratched out values. I read a post of someone finding this controversial in that you will have to do another service mode re-alignment for the convergence; but wouldn't you do that anyways when replacing the IC's and few resistors ? Updated values or not ?
Thanks, I think I'm just answering my own questions lol
So if anybody wonders what the values actually are, here are the updated resistors for CONVERGENCE DP15K/DP15J/DP15H:
43FDXX15B, 43FDX20B
RK42 = 3.3 OHM 1 WATT
RK46 = 1.5 OHM 1 WATT
RK50 = 2.7 OHM 1 WATT
RK54 = 1.5 OHM 1 WATT
RK58 = 4.7 OHM 1 WATT
RK62 = 2.2 OHM 1 WATT
53FDX20B, 53SDX20B, 53SDX20BB
RK42 = 3.9 OHM 1 WATT
RK54 = 1.2 OHM 1 WATT
RK62 = 1.8 OHM 1 WATT
These are all metal oxide fire proof resistors.
Hope that helps someone else down the road.
Sorry for the typing error on the tv model numbers, the first set should say
43FDX15B and 43FDX20B :P
