I need the code for remote an instructions an code to reprograme my remote the model is AKAI KC02-D2
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
i have this same remote and it stopped working after about 6 months and am also finding it very hard to find answers anywhere on the internet and especially fom akai themselves about how to fix it. Or if it can be fixed....should have know not to buy the cheap knock off brand tv
Hey I really need codes for Sony DVD player on this remote and a JVC receiver.
Is there codes for Sony DVD player and JVC Receivers?
Yeah, I wonder if there's a rebranded remote somewhere through Westinghouse. My fiances parents have an LCD with the same looking menus so they must have the same programming.
