Radio Communications Logo
Anonymous Posted on May 13, 2012
I have a cobra29 LTD Classic and the ant warning led lights each time I key the mike. I have the radio mounted in an overhead dash, the radio is grounded to the truck via the power plug. That ground goes to the frame which is grounded to the battery. The antenna mount is also grounded to the frame. The antenna fastener is grounded to the mount. The ohm meter shows 0 ohms at all ground points. I tested the antenna mount and fasteners for shorts between the shield and the center post and none are present...at the antenna mount...at the radio where the coax connects to the radio I am seeing continuity from both the shield and from the center post receptor to ground. This is with the radio off. Any ideas?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
564
Points
A VSWR meter is your best bet. They are cheap for cb's . If the antenna is badly mismatched you will get an antenna warning lamp on. If the antenna has a tuning coil you will see usually continuity to ground from the whip. Use the vswr meter on the radio. Set to calibrate first, transmit on channel twenty while rotating the swr cal knob. set needle on orange triangle at top right of scale. Select VSWR mode and transmit. needle should move up slightly if antenna is tuned correctly. Try chaneel 1 and 40 with same procedure. You can tell if antenna is tuned more toward the high or low frequency by how high the needle is on the scale. The higher the reading the worse the match is. If there is always a high scale reading then try another antenna that you know works.Watch for flattened/damaged/water in between braid and jacket or corrosion on coax as this will change the coax impedance drastically
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Mar 13, 2009
SOURCE: Coax seems shorted
OK TAKE THE COAX OFF THE CB AND CHECK THE OUT SIDE AND INSIDE FOR CONTINUITY 0 OHMS IT IT DOES NOT SHOW 0 OHMS THE COAX IS GOOD. YOU ARE READING THE CIRCUIT INSID -E THE RADIO AND IS NORMAL.
Anonymous
  • Posted on Jan 07, 2009
SOURCE: Cobra 29 LTD Classic not transmitting or receiving
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Anonymous
  • 3 Answers
  • Posted on Dec 24, 2008
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Aug 17, 2009
SOURCE: With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Steve
  • 3290 Answers
  • Posted on Jul 18, 2011
SOURCE: I have a midland 1001z, with a Cobra HGA1000 18
Hi Harry, I just got your note - sorry that you've been waiting 3 days. Your Midland is the traditional 40 ch 27Mhz CB - unlike the "new CB" that is really the 460Mhz FRS system. The Antenna should work as it too, is for the 27Mhz CB system. You seem to have the power run correctly as the radio does power up and visually works.
The problem could be one of several things. First, adjust the volume to about 1/4 and check the position of the CB/PA switch. It should be set to CB. If set to PA, the mic audio is sent to a speaker that would be connected to the PA jack on the back of the radio. Once the switch is set to CB, you ought to hear static from the radio's internal speaker. If you do not, rotate the squelch counter clockwise until you do - and readjust the volume to your liking. Rotate the squelch clockwise just until the static is silenced. Tune other channels for activity. Ch 19 is popular if you're near a highway, otherwise try them all. Stop on a channel with stronger activity - as you'll have the best chances of contacting this type of station (it is presumed to be closer to you). Key your mic to attempt contact between transmissions (the meter should indicate 3 or 4 for up to 3 or 4 watts output power when transmitting - if it does not, you should check your antenna and coax cable for damage and proper VSWR). The other station can not hear you while they are talking.
If they do not respond, try another channel and begin again. If you are unable to get a response, there may be an issue with your antenna or coax as mentioned above. Make sure that your coax cable is not crushed, pinched or cut. Replace and reroute any portion of the cable that is. Use the correct connectors or approved coaxial splicing devices. Twisting wires and braids together and wrapping with electrical tape is not the way to do it.
You can read some excellent info about VSWR from Firestick - a premium antenna manufacturer - here. I hope this helped and again, sorry for the delay. Please rate my reply - thanks!
2helpful
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
Its a cobra 25ltd when i key the mike sometimes it hangs keyed up and does it with defferent mikes so the mike is not my problem.
take some electrical spray cleaner and lightly spray the inside of the radio where the mic plugs in. could also be a keying diode.
When i hook up my cobra29 LTd to my pickup it keeps blowing fuses. What do i need to do or whats wrong.
HI, my name is John. Red to hot fuse under dash or battery and black to ground hope this was helpful.... good luck John
1helpful
I have acobra classic 29ltd key mike ant lights up replaced stud
First thing, you need to check your SWR, you must have a SWR meter to do this. If you are a trucker, you can get it checked at any CB shack, radio shack, etc, they will check it for free. Next, make sure the antenna driven element is clear of any metal blockage, and that it is getting a good ground at the base, don't know what kind of antenna you using, but the Wilson 1000 is a good one to use, install in midle of cab.........hope this was helpful.....
2answers
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Cobra 29 ltd classic
make shure that the rf gain on the front of the radio is turned up. if you have another mike that you can use on the radio.If the mike has a wire that has broke at the mike connector the speaker will not turn on when you unkey the radio.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
