Everything works except heating function
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
SOURCE: My Maytag MMV4205 Microwave Oven runs but does not heat
With the symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly
cheap fix, and the mag will cost more.
If you or someone you
know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
SOURCE: The microwave stopped heating. Everything else is working fine.
GE MAGNETRON REPLACEMENT
cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
know
There
behind the
At
warnings first:
(if it's not shorted or burned, it's
probably okay)
Since it's within the magnetron portion of the warranty (5-9 years)
but out of the original full warranty (1 year), G.E. will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
Sometimes they will
send you the magnetron to do it yourself.
If nothing else, you
can save about $50-75 if you remove it from the wall and take it to a
GE-authorized servicer.
You can find a
GE-authorized servicer by calling GE Appliance
Service at 1-800-848-7620 or here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
We're happy
of our answer.
SOURCE: GE microwave not heating lights and keypad functional
You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
