SOURCE: PSP will not update
Download it thru the actual Sony PSP site and it will download it to the memory card and there you should be able to update it.
SOURCE: GAME DOESNT START.. psp firmware 3.71m33-2
I KNOW THE SOLUTION
1. REBUTE PSP
2. GO TO CONFIGURATION CHANGE TO SONY SOMETHING...NO UMD ON UMD MODE
3. GO TO ADVANCE CONFIG.. AND ENABLE BOTH SOMETHINGS ..CANT REMEMBER
LOL IF THIS ISNT CLEAR GO ON YOUTUBE AND YOUR SOLUTION SHOULD BE THERE
SOURCE: I cannot update my psp
I've seen this is two different cases - the first is that some Japanese systems seem to only like Japanese updates (check to see if the last digit of the model number is a '0' - Like "PSP-1000"), and the second if that if the PSP was downgraded at some time in the past it's possible that the idstorage is slightly corrupted.
If it's the latter case, then there are programs that can fix it, but you need a PSP that can run homebrew code to run them, and it sounds like you are on the official firmware.
SOURCE: i cant update my firmware
YOU CAN ALWAYS just download the patch manually off the internet, then place the update file into your Games folder.
