Nikon Coolpix S1 Digital Camera Logo
Nadine Rogers Posted on Dec 22, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon Coolpix Hi, im wondering if someone can help me so close to christmas. I last used my camera a week ago and it was fine. however when i went to use it last night the viewing screen just stayed black as though i was take a picture in the dark (yes the lens cover was open) i can take a picture but its just black. All the other functions are fine. My mum admitted to trying to show my sister some pictures on my camera but accidently went into image mode so she switched it off. However i have tried changing all the settings and resetting the camera and formatting the card but to no avail. Please help as i was without a camera last christmas! Nadine
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Nov 11, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
2660
Points
34
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
313
Points
My S1 had exactly the same problem. I tried smacking it around as suggested and it worked!!!!! I am SO happy to have my camera back, and for free. THANKS!
It took several attempts to free the stuck shutter in the lens but this did fix my camera!
  • Anonymous Jul 31, 2008
    it's been 6 months now and the camera is still working great. The stuck shutter hasn't stuck again.
A
Anonymous
My camera was under warranty for parts only but labor was $100 by Nikon i guessed better than throwing away should try to fix it, i am just done fixing mine, heres what i have to share: 1 you gotta open it up, it comes off pretty simply. the lens mechanism and the circuitry is totally separate. 2. take the lens mechanism, there are three tiny screws at the bottom going into the plastic. remove these. 3. remove the black protective tape and very gently try to separate the joined plastic parts. 4 it will open up, in three separate portions, in one of them near the aperture shutters (sliding irregular shaped thin plastic pieces) there will be arc shaped pathway for a shutter make sure that this open and you can see across to the other chamber, just slide it with a pin (it only slides one side) to one side and it locks and stays in a corner. You have to be gentle,patient and comfortable with openining and closing circuitry and small components. you would need a philips 0 and a tweezwer for this.
Anonymous
Level 1:
  • Posted on Mar 08, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
313
Points
I got mine broken as well, no abuse or anything. I've tried to search everywhere for a solution, but I guess the best guess is that the CCD is broken, as I can still see the old pictures, menu text and so on and can take pictures, but the pictures are black. I've tried to reset, take out battery, memory card etc, but that doesnt work. I'll try to send it in for repair on the guarentee, as I've seen some cameras are repaired for free, http://www.imaging-resource.com/badccds.html#cause
Anonymous
Level 3:
President:
  • Master 2,961 Answers
  • Posted on Dec 22, 2006
Anonymous
Master
Level 3:
President:
Answers
2961
Questions
Helped
1638381
Points
8444
Can't seem to find anything about the monitor setting other than this
Nikon coolpix wont transfer photos onto my Windows 7 laptop anymore
First, make sure your camera is turned on before you plug the usb cable into your computer.
Camera constantly takes blurred pictures
Appears that the auto focus mechanism is not working, This anomaly is most obvious in lower light situations when focusing is much more critical.
If the camera was new and two months old I would either return it for another one or have Nikon repair the lens assembly under the terms of its warranty.
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
2answers
Broken Nikon L20 LCD Screen
door where the battery goes broke
My Nikon Coolpix L3 camera won't power up. I've checked the batteries and they're okay. I've tried connecting it to the PC with the USB cable, but still nothing. The last time I used it was about 6 weeks...
This camera will not run from the usb. It needs batteries or an adapter. Some small digital blister pack kind of cameras can run from the usb power from the computer or other source.
Make sure you have full charged batteries.
Take the batteries out, and check for corrosion inside the battery compartment. If any is there, clean and try again.
Take care,
1helpful
2answers
Screen
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free.
 John.
LCD not showing view of image to be taken
Nikon Techical Support the quickly this is a CCD or associated component failure
2answers
Nikon Coolpix 5700
Dos not sound good. Did you stor it away with the batteries in I wonder? Try the makers tech support site Is it out of warranty yet?
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
