SOURCE: troubleshooting sony handy ccd-trv 107e
The first thing you should try is removing the batteries for 20 to 30 minutes to reset the unit. If this does not work push in on the cassette mechanism at the top while trying to eject. Also check the tape compartment cover screws to make sure they are tight. Any misalignment in the cover mechanism will cause binding which will create the problem you describe. Finally, and I know this will sound unusual, slap the unit on the cassette side. Forcefully but not enough to break anything. This procedure has been helpful many times with similar problems. I know it is not sientific but hey if it works. If none of the procedures solves your problems you may need professional help. The following websites offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck
SOURCE: "reinsert the cassettee" error in Sony HandyCam CCD-TRV 438E.
The camcorder most likely is not detecting the tape, you have a bad sensor and these sensors all come on a flex type board and the flex board is mounted on the chassis surface. This will mean that the entire mechanism will meed to be diassembled, and is a very big and costly job. My opinion is that this repair will run you abut 250 to 300 bucks and this camcorder is not worth this as new camcorders are under 200 bucks. Good Luck
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
SOURCE: i am having a sony hi 8 ccd trv 58 model handycam.
CCD-TRV58 is analog camcorder and can not be connected with computer directly as camcorder does not have USB or iLink/ DV ports.
Computer needs digital format movie data to store / edit files.
You need to hook camcorder audio-video out to DVD recorder and burn DVD of camcorder movie so you will get digital format of movie. Put that DVD in computer and copy files for further process.
SOURCE: Sony Handycam Vision ccd-trv308
I have the DCR-HC32. I got the c:31:22 error with a message to reload the tape. I could load another tape and saw a post that if a tape is at the end and the tension is tight the camera has a sensor that won't load the tape so that it does not break it. I loosened the tape after a few tries and it loaded fine...no more errors.
