SOURCE: Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
SOURCE: format 4gb transcend flashdrive JFV10. " WRITE PROTECTED"
plug in pendrive right click on it
click on properties
go to tools
and click on backup now
SOURCE: ioctl error . unable to format
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
SOURCE: i cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
SOURCE: i m not able to open or format my 4gb transcend
try using this software to format it..www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
