NEC MultiSync LCD 1560V+ 15 '' LCD Monitor touch-screen
Does this monitor model have touch-screen capability? If so, how hard is it to get the drivers and instruction to set it up? Came in from an auction. Thanks.
I have a LCD of this type - with touch Screen - uses USB connector - came with CD containing drivers - no problems to setup - works well with XP.
P.Evans - Australia
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
