HP Officejet Pro L7680 All-In-One Printer Logo
Janet Kruger Posted on Aug 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Windows 7 op sys in my HP computer. My HP L7680 will now not print an Excel file on legal--reduces the size to letter. Help!
I recently replaced my old HP computer with a new HP computer. My HP L7680 is no longer printing Excel files correctly, specifically, spreadsheets which are designated to print on legal (and have been formttted as such in the printer options in Excel). What the printer prints out is the spreadsheet sized as though it had been formatted for letter-size paper. How do I correct this?
richie46
Level 3:
Top Expert:
  • HP Master 12,962 Answers
  • Posted on Aug 24, 2017
richie46
HP Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945216
Points
58151
Software issue. Contact MS since HP will do nada for you since it is not a printer problem. Maybe your excel program is not really compatible with Win 7. Check it out.
5 Related Answers
Anonymous
  • 115 Answers
  • Posted on Oct 23, 2008
SOURCE: my hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Anonymous
  • Posted on Jan 06, 2009
SOURCE: Re: HP 1320 won't take the tray designation for 2 and 3 Help
Hello classygirl,
I had this exact same problem and resolved it by downloading the HP LaserJet 1160/LaserJet 1320 North American and Western European Full Printing Solution which can be downloaded from support.hp.com.
Because the 1320 does not have a built-in interface, installing the basic drivers will not work. You must download and install the full 400+mb package.
Hope this helps!
Anonymous
  • 432 Answers
  • Posted on Feb 03, 2009
SOURCE: Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Anonymous
  • 5 Answers
  • Posted on Jul 17, 2009
SOURCE: HP 4700 not printing excel files correctly
Only solution I've found is to print to pdf, then send the pdf to the 4700. pdf995 works quick & cheap
Anonymous
  • Posted on Feb 02, 2010
SOURCE: Crooked Excel Spreadsheet
I also had this problem, through trial and error I found that if you go into File, Page setup in excel then the Page tab, make sure the print quality is set to 600 dpi. Once I did that it printed correctly.
HP deskjet 5650 worked great until upgraded to Windows 7 now it will not print on legal size paper
because of your upgrade you may be using a default driver module. You may have to reinstall the driver for the printer from the installation disk, or download it from the HP website.
How do I print a legal size docunent on a HP J3680 without downsizing the copy. While searching the different options in the window of the product I do not I do not find the option for a legal size...
Hello there,
I have the same printer and here is what you can do.
Follow these steps to change the print settings on your computer to print on legal size paper.
  1. Press the Cancel button on the product to stop the current print job, if necessary.
  2. In the software program that you are using to print, click File , and then click Print .
  3. Make sure that the appropriate product is selected.
  4. Depending on the program, click Properties , Options , Printer Setup , or Printer . The Print Properties dialog box opens.
  5. Click the Features or Print/Quality tab.
  6. In the Paper Type or Type Is drop-down list, click the appropriate paper type.
  7. In the Size or Size Is drop-down list, click A5 or Legal .
  8. Click OK to save the settings.
  9. In the Print dialog box, click Print or OK to start printing.
Please do not forget to click the feedback and leave a testimony. If there are additinal questions, i'd be more than happy to help.
1helpful
2answers
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
[email protected]
Bryan
1helpful
Problem with HP 1320 printer
If the paper size in the word document is set to something other than "letter" example if it is set to legal. Then the lite is lit to let the printer user know it is waiting for him to place a sheet of legal paper in the printer, he does so and then presses the green button to start the print job. You can check this by going to "file-page setup" in word and look for the paper size setting.
1helpful
Printing duplex and legal size.
I don't have legal size paper to test this with so it's a theoretical point but it looks like the printer will not do duplex in anything other than:
  • A4
  • Letter
  • B5 (JIS)
  • Executive
You can always print in duplex manually which is always an option regardless of paper size.
Hope that helps.
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
My hp laserjet 4 plus printer cannot print excel files
Hello classygirl,
Hope this helps!
k24674
Grand Canyon Tech
Grand Canyon Tech
