The color on my Panasonic PT-47WX49E tv goes out after prob 10-15 minutes, however when I turn off the TV and turn it back on the color comes back but again goes out. Also the convergence is off some. I have like the blue shadow.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Here are some pics of convergence problems.
The color goes out on my panasonic PT-47WX49E TV. - e87380c.jpgg data-src="/uploadThe color goes out on my panasonic PT-47WX49E TV. - 69189a5.png7380c.jpg" alt="e87380c.jpg" class="h_mi" />
SOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
SOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
SOURCE: blue ghosting on Panasonic PT-47WX49E
your convergence IVs need to be replaced. Its an easy repair if you can solder. you can get the two ICs you need at the following link. they also provide free installation instructions and free on line tech support while youre doing the repair. You need two ICs they are numbers STK392-110. Let me know if I can be of further assistance. I am one of servicemanuals support techs and board rebuilder.
http://servicemanuals.vstore.ca/
SOURCE: I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
SOURCE: Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
