Battery
SOURCE: inserting new drill bit
Assuming that it is this drill:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/7144-04_TYPE_4
You will need a chuck key - hopefully you have that with the drill. It's a little t-shaped bar with a cog on one end. You put it into the holes in the chuck (the part at the end which grps the bit) and turn anti-clockwise to open the jaws. Place a bit in the centre and then turn it clockwise to tighten. Tighten the bit using each of the three holes in the chuck and make sure you remove the chuck key before you use the drill - keep it safe!
SOURCE: where can I purchase anthor battery for the black
Look for a Batteries Plus store near you, If they don't have your battery they can put new guts in yours.
SOURCE: Black and Decker KD950K drill - how to insert drill bit
most keyless chucks have a button on top that you push in near the chuck it locks so you can tighten or undo
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
