i-mate PDA2k Pocket PC Logo
A
Anonymous Posted on May 10, 2012
My i-mate PDA2k shows serial v2.06 and does not work
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Aug 09, 2008
SOURCE: CONNECTING TO THE INTERNET ON MY COMPUTER THROUGH MY I-MATE PDA2K
atta, you are asking a different question, not the same problem. YOU want to use bluetooth to transfer files. The other guy wants to use his phone as a dun.
so, for the other guy.
On this particular phone, only bluetooth dial up networking will work. It will not work as a cable connection. You have to pair the phone with the computer, then set up a connection under dial up networking as a bluetooth modem. The phone number will depend on the network. As I don't know your operating system, I don't know which dun to set up or how to set up your specific bluetooth pairing.
good luck.
Anonymous
  • 35 Answers
  • Posted on Sep 26, 2009
SOURCE: i-mate PDA2k
To be sure if its not the battery thats bad, connect it to the charger and charge for a while. Monitor the light indicator at the top right of the phone.It should start from red to green after its fully charged. then try to restart it by turning on the power button also at the top right of the phone.
If after these procedures the phone does not start up or it shows some temporal 3 seconds flash of power, you may need to get another battery. If a new battery does not start your phone,then its a power fault.It needs to be rapaired.
Anonymous
  • 35 Answers
SOURCE: my I-mate touch Sacreen is not working
Reset your phone! and if you dont mind loosing your information run a complete reset.Then do a screen re-allignment.
To avoid a future re occurence avoid placing your phone in your tight jeans pocket so that you don't apply pressure to the screen.
Anonymous
  • 35 Answers
The i-mate pda2k is not a 3g phone! its only a 2g phone. But you can connect to the internet by using your wireless lan and GPRS.To connect to your computer, go to your phone settings menu then select "connect phone as modem",this will give you the option of connecting through GPRS or otherwise. You must have your settings set up properly to use this feature.
Anonymous
  • 35 Answers
  • Posted on Jan 09, 2010
SOURCE: How do I setup my i-mate PDA2k wireless LAN?
The wireless LAN feature on your phone works by default.If you are in a wireless enabled environment,just go to your phone seetings and select connections,then select the wireless LAN manager which you must turn on; check the box and click o.k.The phone automatically detects all available networks in that place.You can now connect via a password or free as the case may be. This should be o.k.At the base left of the wireless LAN screen is the tools TAB click on this to show you the network card configuration menu.Here you can view all the available networks and decide on some other vsettings as you please.Remember that if your wireless internet requires a password you may not be able to browse till you enter the correct password.
I mate pda2k
yes dear its so easy....install "my mobile" software on your pc and attach ur PDA to it...and then ur mob screen shown on ur PC where u can easily align ur screen using ur mouse ..reply if need more help at [email protected]
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Accessories
I am using an I-Mate PDA2K. My problem is that once I switch on the PDA, it goes repeatedly to the "Messaging"and ultimately it reboots loosing all the data. Battery Power shows "full"upon recharging. And at times the PDA works for a day or two without this problem.
Hari
Pda2k service manual
The i-Mate PDA2k is also known as the HTC BlueAngel. The Service Manual can be found here:
www.mikechannon.net
Mike
2helpful
3answers
good luck.
I-mate PDA2k
Top i-mate Computers & Internet Experts
ExpressFiX
ExpressFiX
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
